Help!! Spring stuck!!!
Old May 17, 2010 | 04:01 PM
SilverBullet08's Avatar
SilverBullet08
Exclamation Help!! Spring stuck!!!
ok I was trying to put my drop shackles on and i removed the bottom bolt and i guess there was alittle more tension on the spring and it shot up and now its stuck... How do i loosen it up?? please any help my is greatly appreciated!!
Old May 17, 2010 | 04:10 PM
MikeHTally's Avatar
MikeHTally
The spring is jammed in the shackle? Sounds like it might need the rear axle lifted (floor jack or whatever) to take the load off.
Old May 17, 2010 | 04:12 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Is it the bolt that holds the leaves together? If so can you put a c clamp on there and wrench them back together that way?
That may not even be the bolt you're talking about though.
If not that one, like Mike said try to jack up the assembly and take the pressure off the bolt.
Old May 17, 2010 | 04:15 PM
SilverBullet08
its the bolt for the shackle. i had the jack under the rear axle and had it lifted but there was still tension. where should i put the jack then? thanks for the help
Old May 17, 2010 | 04:17 PM
hynes9000's Avatar
hynes9000
if its stuck under the body . just jack up the chassis or lower the rear end. I had my hand stuck between the main spring bolt eye and the chassis lol had to get a buddy to tack up the truck to take the tension off ... broke a couple bones . just be careful when working with springs hahaha
Old May 17, 2010 | 04:19 PM
Ice-Forever's Avatar
Ice-Forever
That sounds terribly painful lol
Old May 17, 2010 | 04:21 PM
hynes9000's Avatar
hynes9000
haha wasnt fun . make the best of it, it was 3500 heavy duty springs lol .. my fault never had the chassis up high enough.
Old May 17, 2010 | 04:35 PM
SilverBullet08
ok i got the shackle out and can move the leaf but need to move it more to get the new shackle on
Old May 17, 2010 | 04:37 PM
hynes9000's Avatar
hynes9000
im guessing your rear end is as low as it can go . and you've lifted the truck for more space?
Old May 17, 2010 | 04:45 PM
RedTruck-VA's Avatar
RedTruck-VA
Silver,
The jack should be lifting the frame with the wheel remaining on the ground. This takes the load off the shackle. With the load off the shackle, simply adjust the hieght of the frame to where you can move the spring end back into position with the new shackle. Good luck...
