Codes P0171,174,129
Old May 18, 2010 | 02:32 PM
lancer821's Avatar
lancer821
Default Codes P0171,174,129
I know the codes are lean on both banks and low barometric pressure, but not sure what the problem is. Bought a map sensor from the stealership and it requires modifying/cutting part of the intake manifold because the new style has a longer plug end. This is for a '04 Hemi. Any ideas or help?
Old May 19, 2010 | 08:40 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can try looking here and seeing if it helps
https://dodgeforum.com/forum/3rd-gen...m-alldata.html
Old May 19, 2010 | 05:11 PM
rbutler's Avatar
rbutler
Those codes usually come up if there is air entering after the MAF sensor,check for intake gasket leaks.
Old May 26, 2010 | 10:43 PM
sbsga's Avatar
sbsga
check your egr valve and sensor.
