Steering rack and tie rods?
Old May 19, 2010 | 08:31 PM
dodgehemi64's Avatar
dodgehemi64
Default Steering rack and tie rods?
The steering rack is leaking and I need to replace the tie rods. Where is the best place to get the parts? i was told that the aftermarket steering racks are awful. Also, can I do this myself? Have a 2004 Quad 4x4.
Old May 19, 2010 | 09:47 PM
atv1988's Avatar
atv1988
Had to do this on mine this winter its not too difficult just takes time and make sure the replacement steering rack is full before u install it and that the o ring seals are replaced and count the turns that the old tie rod ends take to come off and put the new ones on the same amount of turns lastly after u fill the ps pump start the truck and idle it for a minute then check the level and top up if needed then turn the steering side to side about a dozen times but not to full lock cause that can damage a new rack. And i used an aftermarket re-man of an oem and havnt had any issues yet
Old May 20, 2010 | 09:52 AM
dodgehemi64
Where did you get it? Also did you get a core charge for your old one?
Old May 20, 2010 | 12:13 PM
FlexJohnson's Avatar
FlexJohnson
I replaced mine in the winter as well (leaking issues)... There was a core charge and I got mine from Napa.. Havent had any issues yet... I wanna say it was 2-300 dollars and I forget the core charge??
Old May 20, 2010 | 01:02 PM
fk1022's Avatar
fk1022
i just replaced my tie rods on both sides and they cost about $30 each at advance auto, as stated count the number of rotations when you take them off and even if your alignment seams ok still get it done mine was off and i couldn't tell
Old May 20, 2010 | 01:45 PM
hoss67's Avatar
hoss67
do not have someone change ur tie rods for you, it takes 15 min tops each side, and they will charge 60 bucks for that.... make sure u get it aligned like stated above
Old May 20, 2010 | 08:46 PM
atv1988's Avatar
atv1988
I got mine from a buddy that owns a garage so I got it for his cost but i belive they run about 280 at carquest plus about 75-100 core charge
Old May 20, 2010 | 10:43 PM
donjohnk's Avatar
donjohnk
go to NAPA! * dont go to the dealer * I almost spit my coffeee in the clerks face when he told me the price for a reman one... got me by surprise! $530, $600 for banny new! i told the guy theyre nutz! im going else where! He agreed..
Old May 21, 2010 | 09:32 AM
dodgehemi64
My mechanic told me to call O'Reily's. They have a reman. original one for $300 plus $100 core. So I am looking at just having 200 in it. Also I am getting the rotors and pads done to. He said he would only charge labor on the rack not the rotors, pads, or tie rods. I was looking at $150 for labor on all of it.
