Grinding Sound
Old May 20, 2010 | 10:38 PM
smallkiller's Avatar
smallkiller
Default Grinding Sound
When I floorboard my truck, every now and again, the RPM will be near redline and hold for a second and then make this horrible, but quick, grinding sound. It's a 2004 automatic with 24K miles
Old May 21, 2010 | 12:17 AM
RedTruck-VA's Avatar
RedTruck-VA
Is there any chance this could be pre-ignition?
Old May 21, 2010 | 07:43 AM
smallkiller
Should I pull out a few of the spark plugs and check em out then?
Old May 21, 2010 | 12:39 PM
RedTruck-VA
I'm reaching on this, but what gas are you using? Do you have a mod list? What gear ratio? What you discribed is usually when pre-ignition occurs and happens more often when 87 octane is used, taller than stock tires and 3;55 gear. I'm keying mostly off of your statement that the engine is hesitating which can be the knock sensors retarding the engine. Just thinking out loud. Good luck...
Old May 22, 2010 | 09:04 AM
smallkiller
87 Octane. mods list include a AFE cold air intake and a muffler delete style exhaust. I have 32'' tires and and extra 2'' of width. gearing is stock, so i'd think it'd be 3;55
Old May 22, 2010 | 12:22 PM
RedTruck-VA
This could be pre-ignition using 87 octane and WOT. It has been noted there can be detonation and piston damage using 87 octane and WOT runs. 89 octane is the recommended octane to use. Check your manual and see what it says to use. But I wouldn't tow or spin the engine up on 87. Search the forum there is a lot of information on this subject. Good luck
Old May 22, 2010 | 12:55 PM
smallkiller
Thanks so much man
Old May 22, 2010 | 12:59 PM
RedTruck-VA
Also, good looking ride!
Old May 22, 2010 | 01:16 PM
dodgenitto's Avatar
dodgenitto
Agreed, just need to lower that @$$ end down a couple inches.
Old May 23, 2010 | 09:05 AM
smallkiller
Bright White FTW =-)
