Wierd Sound from Rear End
I have a 02 Dodge Ram Quad Cab with a 4.7 V8. When ever I go around corners slowly, I get a weird noise comming from the rear end. Its kind of a cross between a wineing and squeaking sound(kind of hard to describe). I'm just curious if anyone else has come across this sound. I've been told to check the rear end fluid and to add some posi additive, and I've also been told that since the rear end is a limited slip diff, that its just the axles sliding back and forth and the rotors could be rubbing since because of the movement. Just wondering if anyone has any other ideas.
Thanks!
Thanks!
