Help with axle wrap /wheel hop
Old May 27, 2010 | 02:45 PM
dodgetimes2's Avatar
dodgetimes2
Default Help with axle wrap /wheel hop
I have an 07 1500 4x4 Sport bone stock that suffers from axle wrap or wheel hop (whatever you want to call it). Truck has 40,000 miles on it. When traveling at highway speeds if you hit a bump it feels like the backend is really loose and wants to get sideways. I've looked into a couple products like the Roadmaster Active Suspension system and traction bars like the Caltracs. Anyone else having this issue? Anyone using the Roadmaster or traction bars?
Old May 27, 2010 | 03:22 PM
Shiloh 24's Avatar
Shiloh 24
Can you feel the wheels tryin to hop so to speak? Like a squeelin sound? If not it's not wheel hop, sounds like your bushings are shot to ****.
Old May 27, 2010 | 03:37 PM
Marx's Avatar
Marx
my truck does that on the highway anything over 100km/h i think its just because the box is empty, it slides to the right about 6 in then its ok kinda scary at first.
how big are these bumps your talking about?
Old May 27, 2010 | 03:44 PM
dodgetimes2
The bumps are nothing major, this is my third Ram and I've never had this issue with the other trucks. No sound when it happens. Just feels like the tires are not planted to the ground. From what I've read the stock springs are fairly soft to give more of a car-like feel and this can contribute to the wheel hop.
Old May 27, 2010 | 03:51 PM
RedTruck-VA's Avatar
RedTruck-VA
Caltracs solved my axle hop when accellerating but I think you have a different issue. Shocks??
Old May 27, 2010 | 04:04 PM
elementalnature's Avatar
elementalnature
From: Home: Southern KY; Stationed: Southern California
Traction bars such as the Caltracs are commonly found on highly modified diesel trucks to help with keeping the tires planted under hard acceleration. The principle of these bars rests on the fact that they tie the axle to frame using thick wall tubing and bushings.
They might help you keep the axle in line with the frame of the truck but I wouldn't bet on it. Sounds like your shocks are shot. If the shocks don't absorb the impact of the bump, the truck can feel like its losing control. If you can stand on the rear bumper and successfully bounce the truck up and down easily then most likely its time for some new shocks.
Old May 27, 2010 | 04:25 PM
RedTruck-VA
Not just for the diesel crowd...
Old May 27, 2010 | 04:29 PM
Cooljay12's Avatar
Cooljay12
Could be that the shocks are already shot and aren't stomping down the way they should. I had that happen in another truck I had and new nitrogen gas charged shock solved the problem pretty quickly. My Hemi has 54K on it now and I'm actually looking for new shocks all around.
Anyone have any good suggestions?
Old May 27, 2010 | 04:40 PM
mexico's Avatar
mexico
if i accelerate and hit bumps the truck feels like the rear is gonna fall out! is that normal? am i going too fast?
Old May 27, 2010 | 04:48 PM
Got_Hemi44's Avatar
Got_Hemi44
New shocks
Cal-Tracs
Hellwig Anti sway bar.
