2007 5.7L loss of power at 4500RPM
Old May 27, 2010 | 06:28 PM
eightyFour's Avatar
eightyFour
Default 2007 5.7L loss of power at 4500RPM
Hello Fellow Ram Owners...
I have a 2007 dodge ram 5.7L Hemi that i love to death. Just on the way home, i went to pass someone who was doing 63MPH and of course i let the horses loose. turns out that when i did the RPM needle went to 4500 at 65MPH and the truck had a massive loss of power. I had backed off the throttle and let the truck idle down. the engine was unresponsive to the throttle and a red warning light was flashing under the RPM gauge. after pulling over to the side of the road, i shut the truck off and restarted it again. The truck acted normal and i attempeted it again, same issue.
thoughts? questions?
this is the first time this has done it. Current mods are only a cold air intake.
Old May 27, 2010 | 07:04 PM
RedTruck-VA's Avatar
RedTruck-VA
What codes are you getting?
Old May 27, 2010 | 07:08 PM
hemiguy0302's Avatar
hemiguy0302
Yep mine did this too the other day. However I was just cruising at about 110 km/h and yeah lost all power. Did a restart and all cool.
Whats up?
No codes either just the red lightning bolt.
Old May 28, 2010 | 10:05 AM
eightyFour's Avatar
eightyFour
Whats up?
YUP! that is the same thing that im getting.... not even one damn code
Old May 28, 2010 | 10:41 AM
Niftymedic239's Avatar
Niftymedic239
That red lightning bolt icon is your warning light for your electonic throttle control. Check, pull and clean your throttle body. If that doesn't work, I would put money on it, that it's your throttle positioning sensor (TPS).
Old May 28, 2010 | 10:49 AM
eightyFour's Avatar
eightyFour
I could give that a try, i placed an appointment at the dealer for wednesday for them to look at it. is the TPS a user replacable part?
Old May 28, 2010 | 09:09 PM
eightyFour's Avatar
eightyFour
UPDATE: I have successfully remedied the problem. i installed the stock air cleaner and filter. it seems to have repaired the issue.
