srt10 oil temp gauge
Old May 29, 2010 | 07:40 PM
bigpappaholt's Avatar
bigpappaholt
Default srt10 oil temp gauge
Im looking at buying the stock srt10 oil temp gauge. anyone done this before? will it work? and what parts do i need to make it work? it just comes with the gauge and maybe 8" of the wires attached to the gauge. Also will an 04-05 pillar fit my 02?
thanks
Old May 30, 2010 | 04:44 PM
bigpappaholt
anyone?
Old May 30, 2010 | 05:04 PM
AF_HEMI's Avatar
AF_HEMI
dont know about the gauge, but the pillar will fit.
Old May 30, 2010 | 05:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
And the guage can be used on that engine like adding one to any engine
Old May 30, 2010 | 05:33 PM
RedTruck-VA's Avatar
RedTruck-VA
Is the SRT10 gauge part of the SRT10 ICC? If so it probably won't work with our Ram ICC. There are plenty of stand alone temp gauges available. Also AI works great for reading many of the trucks sensors and it is plug and play.
AF_HEMI's Avatar
AF_HEMI
It might not be completely plug and play (i.e. wires matching up) because the hemi and srt use different wiring harnesses. but yes, like weedahoe said, you can use any oil temp guage on any engine as long as you wire it properly.
Old May 30, 2010 | 06:48 PM
bigpappaholt
is there a universal sender unit i could get to tap in to my oil pan or whatever to hook to this gauge. i like the look of the gauge alot just trying to figure out what else i need to make the gauge work. any install kit anyone can reccomend?
