2004 ram cab fan issues HELP!
I recently noticed that the air flow seems restricted on both air and heat settings. and when i shift the air flow setting onto recirculation mode i dont hear the normal shifting of air flow, and im wondering if there is a fuse controlling the recirculation function or if anyone else has had this problem and had it resolved.
I talked to a dealership and of course they offered no insight other than i can bring it in for diagnoses accompanied by the $85 fee. Hoping i can avoid this with a little forum advice.
Thanks for your time!
and im trying desperately to avoid that charge. I was going to try picking up a control board thinking the switch telling it to "blend" was bad. But because the air flow is restricted no matter what section i choose, im guessing your right and its probably something stupid like the blend door being stuck. 400-700 to take it all apart and lube the stupid hinge its probably on!!!!!!!!
