Just wondering
Old Jun 2, 2010 | 03:57 PM
Suckingas03's Avatar
Suckingas03
Default Just wondering
I always read on these fourms for hours. Bunch of cool stuff. I was just wondering about tires and level. I have searched but cant really find an answer. I really want to get a 2.5 front and 2 inch blocks for the rear and I can get a good deal on some H2 take off tires which are 315/70/17s. I am thinking they will fit but wanted some answers from the pros before I waste my money. I have a 03 1500 hemi. it has the torsion keys up front. I have 285/70/17 toyo at on right now and they look small in the front with the front T-Bars cranked. Tell me what you guys think and what I should do if you have anything to suggest. Thanks in advance
Old Jun 2, 2010 | 04:50 PM
cwboyjohnny24's Avatar
cwboyjohnny24
You'll either need spacers for the rims or aftermarket rims to fit the pretty much 12.5" wide tire without rubbing. Height you should be fine.
Old Jun 2, 2010 | 05:10 PM
Suckingas03
Thats what I though. I just want a little more lift but need a decent size tire so it wont look too bad.
Old Jun 2, 2010 | 05:41 PM
hoss67's Avatar
hoss67
ok, are the 17s stock? if so i wouldnt run the 315s, drop down to a 305 which i a 33.9x12.1 and they will fit on the stock tires decent. thats wat i am runnin with a 2.5 in the front and stock wheels, looks great and rides good
Old Jun 8, 2010 | 08:23 PM
Suckingas03
If I do go with the 315/70s on my stock 17's what kind of wheel spacers should I get like size?
Old Jun 8, 2010 | 08:27 PM
nim81's Avatar
nim81
im running 1.5" spacers. bolt pattern 5x5.5. make sure you get hub-centric spacers.
also if you do 2.5" level in the front and 2" blocks in the rear you truck will have a lot of rake in the front
Old Jun 8, 2010 | 08:29 PM
Suckingas03
Awsome thanks. and I think I am just gonna stick with 2.5 in the front. Disturbedgators truck is the exact setup I like. Nice height and good size tires that dont look small like my 285/70's.
Old Jun 8, 2010 | 08:31 PM
nim81's Avatar
nim81
just crank your t-bars for free, thats what i did. gained about 3" and dont forget an alignment !
Old Jun 8, 2010 | 08:34 PM
Suckingas03
Yea I got them cranked My front from ground to my fender is sitting at 39 inches I think back is 41 inches. I cant seem to get higher than 39.
Old Jun 8, 2010 | 08:36 PM
nim81's Avatar
nim81
hmm.. idk if new keys would give you more or not... never used the keys
