First time post.. Another ETC question
Old Jun 4, 2010 | 08:18 PM
mike_dmt's Avatar
mike_dmt
Default First time post.. Another ETC question
New to this board, looks great. Looks like I'll be spending a ton of time here in the next little bit.
But, I have an immediate problem to sort out first. I've seen a number of other posts regarding the ETC light, and that's what happened to me just an hour or two ago. Wife was out in my truck, and called and said it wouldn't start. (turned over fine, no start) So I go check all the fuses, relays, listen for the fuel pump etc....Everything checks out. A few minutes go by, and it starts. About a mile later, ETC light flashes, loses power and dies on its own.
Had it towed to my brothers, and when it gets there, he calls me up and says it starts and runs fine.
The other posts/threads on here say to check codes (will do in the morning) and that a thorough cleaning of the TB will solve the problem.
Long story short.. Does this sound right, or should I be ready to test/check something else? I've seen some threads saying check the battery and charging system. Some saying a few other things.
Sorry for the ridiculously long post, I just want to be fairly clear about what is going on.
Thanks in advance,
Mike D
Old Jun 4, 2010 | 08:19 PM
RubberFrog's Avatar
RubberFrog
Get the code and then get back to us. It could be a million things and I hate to see you tear into it and start throwing money at ghosts.
When is the last time you did a tune up?
Old Jun 4, 2010 | 10:13 PM
mike_dmt's Avatar
mike_dmt
AHHHHHH,,, never. Haha. I just bought it in late October, maybe the first part of November. It has a ton of miles on it, but up until today, zero problems, hiccups or anything that would point to a major issue.
I'll get the codes tomorrow, and reply to get the lowdown. Thanks again!
Old Jun 4, 2010 | 10:15 PM
mike_dmt's Avatar
mike_dmt
On another note, RubberFrog, is your hood a one piece SRT style or is that a scoop in your sig?
Old Jun 5, 2010 | 01:15 AM
mike_dmt's Avatar
mike_dmt
Wow, this board moves fast..
Bump for more ideas?
Old Jun 5, 2010 | 06:12 AM
RubberFrog's Avatar
RubberFrog
It's a factory srt hood.
Old Jun 7, 2010 | 09:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Still looking for those engine code numbers.............
Old Jun 7, 2010 | 04:02 PM
mike_dmt's Avatar
mike_dmt
Sorry weedahoe, I had started a new thread with the codes on it, but I'll stick with this one from now on.
So its an 03, with the 5.7 Hemi.
Codes that I couldn't figure out are 2106 and 2108.
I read up on here as much as I could before heading to the shop to work on it, and what I gathered was that the TB needed a good cleaning. So I did, but once I drove it a few miles, it wouldnt start again for about 45 minutes. Finally got it home, and same thing, turns over but wont start. Waited a few hours and it fires right up.. So, I'm assuming it just needs a new one? I don't have a clue what else could make it act up like that.
As far as the TB you mentioned you had laying around, in another thread, I might be interested based on whatever price I get from the stealership here in a bit.
Old Jun 7, 2010 | 05:10 PM
mike_dmt's Avatar
mike_dmt
So I came across these for code descriptions:
P2106 Throttle Actuator Ctrl Sys-Forced Limited Power
P2108 Throttle Actuator Ctrl Mod Perf
So, I called the local stealerships(2), they don't stock the TB I need at either one and recommended I bring it in to have their tech "pinpoint" the problem by scanning it with their obd tool. Well, a friend of mine is a tech and already did that, plus the codes come through the truck itself already, so I'm wondering why I should give them $100 to tell me what I have already been told.
Does this sound like a TB issue to you guys or something else? I dont want to throw $200 at a new one to have it be something else, obviously.
Old Jun 7, 2010 | 06:36 PM
black shadow's Avatar
black shadow
I am sure that Rubberfrog will point you in the right direction.
