Tie rod ends
Old Jun 7, 2010 | 02:31 AM
Rookie1500's Avatar
Rookie1500
Default Tie rod ends
So I have been tinkering around with my truck a little, and noticed one of my tie rod ends needing to be replaced. But i found it odd that on my '06 1500 QC 5.7L that the tie rod ends do not have any grease nipples.
I would rather not stick new tie rod ends on that do not have grease nipples, but also dont want junk ends.
Does anyone know of any good tie rod ends? Or is there much of a difference from the stock ends and any of the other ends that have grease nipples?
Also i think it is a pretty straight forward change, just count the turns when i take the old ones off, and go for a wheel allignment. Does that about sum it up?
Old Jun 7, 2010 | 03:01 AM
OlDirtyJohn's Avatar
OlDirtyJohn
check out www.rockauto.com . they sell moog, mevotech, and a few other brands of grease-able front end parts. many of them have lifetime warranties.
Old Jun 7, 2010 | 03:17 AM
Rookie1500's Avatar
Rookie1500
Wicked site, thanks John!
Old Jun 7, 2010 | 07:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
yeah it really sucks that nothing under a 1500 has any grease fittings.
Old Jun 7, 2010 | 10:18 AM
OlDirtyJohn
shi!t, nothing under the 2500 has grease fittings either. dont feel too bad.
Old Jun 7, 2010 | 10:52 AM
Denniss66's Avatar
Denniss66
its funny how this came up just a few weeks ago the old man was giving me crap about not greasing my truck enough cause my lower ball joints were pooched yet nothing had grease nipples but the drive shaft. but anyways depending on the k and what you put your truck threw expect on doing those too.
Old Jun 7, 2010 | 02:27 PM
kx250frider617's Avatar
kx250frider617
I changed mine, I measured 4 times to the mm as best as I could. Never got an alignment and my truck runs perfectly straight. I can let go of the wheel doing 70 mph and it tracks perfect. I would pay someone to do that kind of work. The hardest part was getting the taper of the knuckle, which does NOT require force with a huge sledge hammer. I used a regular metal hammer and just tapped it quickly. The resonance of the metal pops it loose.
Old Jun 7, 2010 | 05:21 PM
nim81's Avatar
nim81
never in my almost 4 years on this site,have i seen the word "nipple" used so many times in one thread! lol ive always heard them called zerk fitting..
and kx250frider617 : just cause your truck drives straight doesnt mean its in alignment.. i would have a shop do it or your gunna ruin some tires
Old Jun 7, 2010 | 07:33 PM
Rookie1500's Avatar
Rookie1500
Yuck, sounds like i got a ton of work to do then... I just hit the 100k km mark a little bit ago.
Thanks for the replys and the tips!
Old Jun 7, 2010 | 09:02 PM
ekgaudio's Avatar
ekgaudio
I just replaced mine and they have grease fittings. (07 1500) They are just cheapos from Auto Zone.
