Just wanna make sure before I pull the trigger
Old Jun 8, 2010 | 07:38 PM
huseman808's Avatar
huseman808
Default Just wanna make sure before I pull the trigger
I am ordering a set of Cooper Discoverer STT's 33x12.50x17.
And a set of these Crager Soft 8 rims. Heres the specs
17in diameter
9in wide
5 x 5.5 bolt pattern
5in backspacing
My truck is at stock ride height with the exception of a T-bar crank to level the front end up. I want to make sure that I wont have to return anything once I purchase them.
If you guys could let me know of anythiing I am missing I would appreciate it very much. Thanks
Old Jun 8, 2010 | 07:44 PM
blakeroberts88's Avatar
blakeroberts88
33 inch tires fit no problem on our trucks. My truck has the stock 33's on stock ride height.
Old Jun 8, 2010 | 07:45 PM
nim81's Avatar
nim81
BADASS! your good to go my friend! cant wait to see them installed!
Old Jun 8, 2010 | 07:55 PM
cwboyjohnny24's Avatar
cwboyjohnny24
You may have enough backspace on the rim to where you don't have rubbing. The 33 isn't the problem I see as long as the 12.5" wide doesn't rub the uca. That's the only thing I would worry about. Nice setup though for sure.
Old Jun 8, 2010 | 08:04 PM
nim81's Avatar
nim81
no way it will rub with 5"backspacing!! it wont rub with 4.5" backspacing!
hell im runnin 33x12.50x17s with 1.5" spacers. no rub
perfect setup!
Old Jun 8, 2010 | 08:20 PM
HammerZ71's Avatar
HammerZ71
You'll be fine, nice combo too, IMO...
