Wiring Question
Old Jun 9, 2010 | 07:54 PM
COTFAN's Avatar
COTFAN
Default Wiring Question
I need a ignition only power source.
The left cig lighter is only on when the truck is on. The right power outlet is constant.
How can I remove the cig lighter to tap the power source.
I need it for a light on the Air Compressor gauge in the truck.
Old Jun 9, 2010 | 07:56 PM
dirtydog's Avatar
dirtydog
Moderate User
You need to pull the whole bezel off to acess the backside. I don't think it will pull through due to clips holding it on.
Off_Road_Teacher's Avatar
Off_Road_Teacher
If you twist and pull it should just pop out. I used the cigar lighter wiring to power my e-cutout.
Old Jun 10, 2010 | 05:54 PM
COTFAN's Avatar
COTFAN
I located my air compressor command module next to my ebrake. Is there a power source in this area I can tap?
Thanks
Old Jun 11, 2010 | 06:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You need to invest in a cheap meter or test light. There are lots of wires you can tap or even run from the battery through the firewall right there to that area.
Old Jun 11, 2010 | 07:13 AM
MikeHTally's Avatar
MikeHTally
Thanks
Under the steering wheel, behind the knee bolster is a four-wire harness. Often not used, it has a lime green/black stripe wire. That is a switched hot, but why not tap the instrument panel lights? There's a wire above the lighter (brown & black, I think), which is the ashtray lamp wire.
Old Jun 11, 2010 | 08:08 AM
HammerZ71's Avatar
HammerZ71
I'm with 'Weed. Invest in a cheap $10 meter at Radio Shack... I've used mine for e-fan install, cab light install, off-road light install, etc...
Old Jun 14, 2010 | 07:48 AM
Gasturbine's Avatar
Gasturbine
Actually, I find a test light better than a meter for this type of hunting. Just get one that has a really small and sharp point. And if you "poke" any wires outside the cab, Id put a dab of silicone on the hole.
-Chris
