Please help with stalling during warm up
Old Jun 10, 2010 | 12:17 PM
jeepdude's Avatar
jeepdude
Default Please help with stalling during warm up
Hey people,
Im new here and this forum looks awesome!
I do have a question though,
2002
ram 1500
5.9 l
auto
slt
Just recently I noticed that my truck would act funny during warm up. It starts great. But about 1-3 minutes later it starts idleing rough. I have a cool air intake so I can also hear that is sounds like it is sucking ALOT of air while it is hesitating. I also noticed that if i drive it after starting it the truck will drive for a minute then hesitate. I can turn the key off then on while coasting and then it runs fine for a bit. It may happen 2-3 times in the first 5 minutes of driving. After it is warmed up it'll run great for hours with no problem.
I thought a tune up might help so I replaced the plugs, wires, dist cap, rotor, oil. No change. I cleaned the intake inside and out. NO Change. I put in injector cleaner...no change.
Please help me....... Someone must know what causes this for sure.
Old Jun 10, 2010 | 12:24 PM
jeepdude's Avatar
jeepdude
could the battery cause this???
Old Jun 10, 2010 | 01:29 PM
HammerZ71's Avatar
HammerZ71
Sounds to me like you are running a bit lean. The engine should be running a bit extra rich until it comes up to temp when it reaches open loop and uses information gathered by various sensors to adjust the A/F ratio.
Could be a number of things including a dirty throttle body, but I'd start by checking your mixture when the engine is cold since this seems to be when your issue takes place...
Old Jun 10, 2010 | 01:39 PM
jeepdude's Avatar
jeepdude
thank you for your help!!!!
I did pull off the throttle body and cleaned it. Looked inside the man with a scope and It all looked good.
I am wondering what part (sensor) on the truck would cause the confusion in the mixture while it is warming up.... O2??? Mass airflow....
Sorry .....kind of a dummy
Old Jun 10, 2010 | 02:22 PM
jeepdude's Avatar
jeepdude
Bumps
Old Jun 10, 2010 | 02:35 PM
Gasturbine's Avatar
Gasturbine
Do you have any trouble codes?
Check the fuel rail pressure, and confirm the IAC motor is working.
Sensors rarely go out of spec...they usually break, and set a code.
-Chris
Old Jun 10, 2010 | 04:37 PM
jeepdude's Avatar
jeepdude
I'll check that tonight after work!!! thank you
Old Jun 11, 2010 | 11:19 AM
jeepdude's Avatar
jeepdude
-Chris
Nope no trouble codes. No check engine light.
Ok well I pulled my IAV motor out and cleaned it. I replaced the battery. no change this morning. It still wanted to stall out within 5 minutes of starting and smooths out after a couple resets.
ANYONE >?????
Old Jun 11, 2010 | 11:59 AM
jeepdude's Avatar
jeepdude
Bumps. HELP
Old Jun 11, 2010 | 01:55 PM
dakota_raven's Avatar
dakota_raven
dirty fuel filter, bad fuel pump??
