Lifting a 2WD
Old Jun 11, 2010 | 10:17 PM
  #21
BigD's Ram's Avatar
BigD's Ram
Ok so u think instead of the 3" rc lift I should do the 2.5" levelin spacer and a 3" body lift will I be able to clean 35' s and it not look stupid?
  #22
KrisKountry's Avatar
KrisKountry
Default 2wd lift
I have an 04 2wd and for me to feel comfortable with 35s I bought the CST lift kit which raises the front 7" with new spindles and coil springs and the back 4" with blocks. I don't know the cost of your 3" lift but I paid around $1,100 for my kit and bought stock length Pro Comp ES3000 shocks from 4WheelParts. My only regret is that I didn't spend a little more on the shocks because it rides pretty rough and on gravel roads with the washed out sections the ride can get a little scary at anything over 45mph. Because of the extra weight of my Ranch Hand front bumper I ordered the Mega Cab kit for my regular cab truck, this was recommended by the company to compensate. Hope this helps, I have pictures on my profile I think, take a look and see if that's the look you are after.
ps: body lifts are bad, if you have a hitch it will sit 3" lower than your bumper IF you get the bumper brackets along with the lift. Everything under your truck will be out in the open and doesn't look too good, even with the gap filler kits. When it's all said and done (lift, bumper brackets, installation, gap fillers) you will end up spending close to what you would spend to purchase the suspension kit that I did and installing it yourself. If you are fairly mechanically inclined you can get it done over a weekend in your driveway like I did.
Old Jun 11, 2010 | 10:19 PM
  #23
ram man17's Avatar
ram man17
Si. Or you can do the 3" lift (removing your spacer you have now and not using the 1.5" blocks for the back) to level it and on top do a 3" body.
Old Jun 12, 2010 | 01:11 AM
  #24
grap660's Avatar
grap660
Originally Posted by BigD's Ram
Grap660 if I put the 3" rc lift on can I leave my 1.5" block in the front and then put the 1.5" block in the back and will that make it level....or do I have to put the factory block back in
sorry for the late reply but yes put the stock block back in if you get the 3 inch rc coils. bodies lift are kinda nice but i dont like them but since you have the 1.5 inch spacer alrdy i would suggest getting 4 inch spindles from cst or doetsch its cheaper getting them at suspensionmax i heard they supply the spindles to both companies and are cheaper anyways basicly your 1.5 inch plus the 4 inch spindles well = 5.5 inches of lift good enough to fit your 35's
Old Jun 12, 2010 | 12:19 PM
  #25
BigD's Ram's Avatar
BigD's Ram
Grapp660 is there a website I can get the 4" spindles from and how hard are they to install?
Old Jun 12, 2010 | 12:22 PM
  #26
BigD's Ram's Avatar
BigD's Ram
And if I do the spindles will it just lift the front?
Old Jun 12, 2010 | 12:23 PM
  #27
BigD's Ram's Avatar
BigD's Ram
And how much are the spindles?
Old Jun 12, 2010 | 01:17 PM
  #28
grap660's Avatar
grap660
here the websites for spindle i never installed any so i dont know how hard is it the kit i would suggest getting is the suspensionmax ones because its a good deal and you will just need new shocks
http://shop.suspensionmax.com/Shop/C...4010/SFV/32526
http://www.cstsuspension.com/product...ID2/8/sfID3/66
http://www.doetsch-shocks.com/15.asp
Old Jun 12, 2010 | 01:46 PM
  #29
oefootball_70's Avatar
oefootball_70
here is a RC 6 inch lift with 34's
Old Jun 12, 2010 | 02:38 PM
  #30
BigD's Ram's Avatar
BigD's Ram
So if I get the 4" spindle kit from suspenionmax will it come with everythin I need for the front and back and will I be able to put 35's on it?
