Lifting a 2WD
Old Jun 26, 2010 | 03:07 PM
  #61
red ram ridin's Avatar
red ram ridin
by the way i have a 03 1500 2wd
Old Jun 26, 2010 | 03:31 PM
  #62
red ram ridin
new crossmembers needed?
Old Jun 26, 2010 | 03:36 PM
  #63
Matt99's Avatar
Matt99
no that should come with everything minus alignment. Spindles actually drop the front tires, essentially lifting the truck. you shouldnt need new coils and 4in up front will be nose end up even with a 1in block. I have a 2.5in spacer and a 1 1/2 in block out back and am almost level
No crossmembers, a arms, steering stabilizers....the only thing you MIGHT need is longer brake lines, but seeing that you are under an 06 you wont even need those
Old Jun 26, 2010 | 03:39 PM
  #64
Juggernaut09's Avatar
Juggernaut09
Who cares, save your money, its a 2 wheel drive! It's a weekend hauler.
Old Jun 26, 2010 | 04:03 PM
  #65
Matt99's Avatar
Matt99
actually many of the nicest lifted trucks in magazines, shows, etc are 2wd. On top of that, most peoples work trucks/hauling vehicles are 2wd. If there is no need for going through slop, 4wd is just alotta extra crap to go out 5-10 years down the road
Old Jun 26, 2010 | 04:13 PM
  #66
red ram ridin
thanks matt. suspension max has a spindle lift here.
http://shop.suspensionmax.com/Shop/C...4010/SFV/32526
Are you saying that I dont need new shocks or coils? I guess those are for lifting the truck off the tires but your saying the spindle drops the tires from the truck basically
Old Jun 26, 2010 | 05:36 PM
  #67
Matt99's Avatar
Matt99
http://www.airbagit.com/product-p/x2-spi-dod-06.htm
exactly...by dropping the tires it lifts the truck. I think with that kit you will be level, maybe a tiny bit over. Blocks are $25
You dont need new shocks/coils with a spindle lift...you can buy longer coils/spacers for the coils and it will lift the truck additionally. The spindle is a better way though, honestly. With the spacer/coil you do need longer shocks
Old Jun 26, 2010 | 06:26 PM
  #68
red ram ridin
well then my only dillema is whether or not i can fit the spindles on my stock 17 inch rims. Then its HELLO nitto terra grapplers
Old Jun 26, 2010 | 08:29 PM
  #69
Matt99's Avatar
Matt99
look at post #51
Old Jun 26, 2010 | 11:26 PM
  #70
red ram ridin
but has someone done it? to see if it does rub?
