Lifting a 2WD
Old Jun 11, 2010 | 07:54 PM
BigD's Ram's Avatar
BigD's Ram
Default Lifting a 2WD
I have a 2005 Ram 1500 2WD i want to put a 3 inch rough country lift suspenion lift on it will it fit 35"s with 22 inch rims under it and not scrub?
Old Jun 11, 2010 | 08:27 PM
ram man17's Avatar
ram man17
No way jose. The rough country kit is basically a leveling kit with 1.5" blocks in the back. You will need the 6" kit or 3" body
Old Jun 11, 2010 | 08:37 PM
BigD's Ram's Avatar
BigD's Ram
Is urs a 2WD? Cause i have a 1.5 block in the front now and i have 33's on 20's and there no where near scrubin....so i figured if i put there 3inch suspenion lift i would be able to put 35's
Old Jun 11, 2010 | 08:44 PM
nim81's Avatar
nim81
you shouldnt have any problems. a 35" tire is 35" no matter what size rim its on. just make sure the rim has enough backspacing for the width.
Old Jun 11, 2010 | 08:48 PM
ram man17's Avatar
ram man17
You have a 1.5" block in the front? and yes mine is 2wd
Old Jun 11, 2010 | 08:51 PM
BigD's Ram's Avatar
BigD's Ram
Yes i have and 1.5 block that was suppost level it out but it didnt thats y im gettin the 3 inch lift from rough country i just need to know if it will fit 35's cause i have 33's on it now
Old Jun 11, 2010 | 09:05 PM
BigD's Ram's Avatar
BigD's Ram
Its called a buget boost its just a spacer that sits on top of the coil spring it was suppost to level out my truck but it didnt
Old Jun 11, 2010 | 09:07 PM
nim81's Avatar
nim81
you should go with a 3" body lift and problem solved .
Old Jun 11, 2010 | 09:09 PM
grap660's Avatar
grap660
on the 3 inch rc lift you dont really need the blocks that comes with the kit becuase the bed is at 39 inches so when you put the rc 3 inch coils you be at 39 for a perfit level the 1 inch blocks that come witht he kit well still give you the rake
Old Jun 11, 2010 | 09:17 PM
ram man17's Avatar
ram man17
x2. With the 3" lift it only lifts the back 1.5". 3" body lift is 3" all around
