2004 1500 Hemi headlight problem - It is never easy!
Old Jun 12, 2010 | 11:14 AM
Jeff816's Avatar
Jeff816
New Member
Default 2004 1500 Hemi headlight problem - It is never easy!
My passenger headlight is out. It started not working intermittently and some times just turning the switch on and off fixed it. Then it went out totally. I changed the bulb and of course that didn't fix anything. I checked all connections and wiring that I could and found nothing. I took it to Tire Kingdom and after about four hours and a nominal fee they told me they checked everything they could and also found nothing. They said I need to take the truck to an "Auto Electrician". About 2 weeks later it fixed itself again for about a day and a half then went out again. It has been about a month now with no change.
Has anyone ever had this problem or have any ideas? I'd like to have some idea of what is going on before I go to the shop.
Old Jun 12, 2010 | 11:26 AM
Big_Wheel's Avatar
Big_Wheel
im having a lighting issue on my 2004 1500 hemi also... but both my head lights/tail lights will come on randomly..or will randomly not shut off.. i was told to check the switch but im thinking it may be corrision in the fuse panel. For your problem i've seen a loose fuse do that
Old Jun 12, 2010 | 03:11 PM
hemiguy0302's Avatar
hemiguy0302
Sounds like a front control module issue. Search front control module FCM on this forum.
Old Jun 12, 2010 | 05:44 PM
MikeHTally's Avatar
MikeHTally
Tire Kingdom can't find their butts with both hands. I'd guess intermittent ground. TK was right about one thing - you may need someone experienced with auto electrical "stuff".
Old Jun 14, 2010 | 07:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
FCM is exactly what i was going to suggest also.
