Engine blocks
Old Jun 12, 2010 | 03:39 PM
ljhopp's Avatar
ljhopp
Default Engine blocks
Are the 2002 ram blocks the same as the 2008 ram blocks?
Can you put 2008 ram heads on a 2002 ram block?
I am wonder because the 2002 ram has like 250 hp and 2008 ram as like 310 hp. I know the new head use 2 plugs. I am wonder if i can put new heads on and will see a an improvemt in hp?
Old Jun 12, 2010 | 09:13 PM
HemiLonestar's Avatar
HemiLonestar
It would help if you were specific on what engine. From what you have for numbers, I would assume it's a 4.7? So far as I know (4.7 gurus will chime in), there are radical differences between the 02 and the 08.
Old Jun 14, 2010 | 07:02 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, I was going to say the same because an 02 big v8 came with a 5.9L and not a 5.
7 that a 08 would have come with.
Old Jun 15, 2010 | 10:37 PM
ljhopp's Avatar
ljhopp
Yes, I am talking about the 4.7.
Old Jun 16, 2010 | 01:13 AM
HemiRam1566's Avatar
HemiRam1566
heads are everything, im guessing blocks are close to the same.
Old Jun 16, 2010 | 08:06 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Nick over on DT swapped later year heads on an earlier year block. IDK if he got any more power or not though.
Old Jun 17, 2010 | 12:51 AM
ljhopp's Avatar
ljhopp
If the blocks are about the same and the heads don't give you that much hp increase, are they getting the hp increase from just programming?
Old Jun 17, 2010 | 09:20 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Most guys do on stock builds. Its the only way.
