Problems of New Owner 2006 RAM 3500
Old Jun 15, 2010 | 11:53 AM
Zmax's Avatar
Zmax
Default Problems of New Owner 2006 RAM 3500
I bought the truck in auction then I brought it in a dealer for inspection, it was diagnosed to replace with upper and lower ball joints and front axle U joint, there's a considerable play in driver side and very minimum on the right side.
I did the work myself last Sunday, I installed unfortunately the axle wheel bearing assembly was split apart when we removed it, one sticking to the steering knuckle while the other wheel hub nut was removed by a puller.
I installed the Upper (Moog 7460) and Lower (Moog 7467) Ball Joints. I FOUND out that the Upper Ball Joint there is a little play even it's new, IS THIS NORMAL? and I CAN ROTATE it in my hand easily, Even the other one, not installed yet, I CAN rotate it in my hand easily.
I am scared, sad , dismayed with my endeavor. With the hard work and time spent, I almost cry on this.
Also, I browse in the internet for axle bearing hub assembly and I found a BRAND : Replacement , IS THIS OK, I was given a a good deal supposed to be yesterday for less than $200 but I hesitate, not familiar with this name? Please advise, I can save $160 if I buy this , it's $360 here in Alberta, Canada
http://www.autopartsdeal.com/catalog...ment+Wheel+Hub
Please advise, I did not use this truck much since I bought coz Im scared, the dealer said it's too dangerous to drive. Now, I m stuck with repairs and parts problems,
Old Jun 15, 2010 | 01:29 PM
Huntjunkie41's Avatar
Huntjunkie41
Usually new ball joints have some resistance before installation however they vary by brand. The upper ball joint if it is new should be fine. It is not a load bearing surface. If you baught it new and are skeptic about it then take it back for a new one. The wheel hub you found cheaper will work fine . I have replaced hubs with unknown brand name parts and they were identical to the original part. They are required to be manufactured to meet or exceed OEM standards. $200 is reasonable price.
Old Jun 15, 2010 | 02:20 PM
Zmax's Avatar
Zmax
Thank You for your advice.
I wish to return it to rockauto.com but if this is normal then, I will keep it. I thought to ask a mechanic to see it.
