What is this noise???
Old Jun 15, 2010 | 07:38 PM
popdog's Avatar
popdog
Default What is this noise???
So i was spending some time under my 05 QC hemi, and i noticed I hear this fairly loud "clank clank clank clank", that sounds as if it's coming from my oil pan. It increases in frequency if you step on the gas, but goes away once you hit 1000-1500rpms. It almost sounds like a bolt rattling around but in a consistent time with the engine. If I grab the sides of the oil pan I can basically feel the pulsing from the weird clanking. Anyone know what this might be?
Old Jun 15, 2010 | 10:02 PM
RedTruck-VA's Avatar
RedTruck-VA
Popdog,
Hate to say this, but it sounds like you have a real problem. If you can't isolate the noise you need to get a professional diagnosis, as it sounds more serious than the common hemi tick. Good luck...
Old Jun 15, 2010 | 10:13 PM
Big_Wheel's Avatar
Big_Wheel
do you have good oil pressure???
Old Jun 15, 2010 | 10:42 PM
popdog's Avatar
popdog
Oil pressure is fine...i've only got 36k on her. Friend of mine thought it might be the main bearing when I described it.
Old Jun 16, 2010 | 01:14 AM
HemiRam1566's Avatar
HemiRam1566
sounds like a rod bearing possibly
Old Jun 16, 2010 | 02:45 AM
huseman808's Avatar
huseman808
sounds like uneven wear on your main bearing to me. bummer man
Old Jun 16, 2010 | 02:09 PM
popdog's Avatar
popdog
Yeah...I'm not ruling it out of coming from a bearing in the trans and echoing through the crank case....anyone have some ideas on what kind of repair cost i'm looking at? it's not audible unless you're listening below the truck so it doesn't sound like anything is completely shot... listening from the engine bay she's pretty quiet
