Stupid question time - LUG NUTS / Tire Iron / wont fit
Old Jun 18, 2010 | 12:11 PM
boyd98's Avatar
boyd98
Default Stupid question time - LUG NUTS / Tire Iron / wont fit
K -
last week i had some bad luck, battery died and found my tire had a screw as wrecker picked it up
after i replaced the batter, I put on the spare not paying any attention to how deep or how much my tire iron went over the lug nuts - it went over good enough to break them loose and tighten....
Got the tire plugged and two days later the tire is flat again.
This time, when i went to change it, i really noticed that the tire iron would not fit over the lug nuts, and that id probably strip them if i tried. Now i can't imagine i did the first change like this without noticing. Which makes me wonder, did the tire place put on the wrong lug nuts.
So i called them, they let me borrow a 4 part tire iron. Now the biggest setting on that tire iron would only still go about half way deep on my lug nuts.
All my other tires i can put my original iron on all the way on??
My question is - did the lug nuts expand since the tire was completely flat; like it might have tilted and applied enough pressure to swell the lug nuts....
Do lug nuts change size...is it more likely they put the wrong ones back on in a rush
I still see the hole where the screw was; and have never had a patch not hold before - did this place just suck -
sorry for the long winded background - the short version is - will lug nuts expand or change size on there own if you have a flat and let them sit long enough?
Old Jun 18, 2010 | 12:36 PM
Mega-Hemi's Avatar
Mega-Hemi
They probably used an impact on your lugs. If they use one that's just a little too big it will deform the lugs and cause the proper socket not to fit.
As for the leak, you could have more then one.
Old Jun 18, 2010 | 01:20 PM
HammerZ71's Avatar
HammerZ71
Ain't sposed to use an impact on aluminum lug nuts... but they all do anyway...
Old Jun 18, 2010 | 01:46 PM
boopadoopa's Avatar
boopadoopa
There was just a thread earlier this week about lug nuts bulging?
https://dodgeforum.com/forum/3rd-gen...ts-bulged.html
Old Jun 20, 2010 | 06:08 PM
boyd98's Avatar
boyd98
Thx fellas - after reviewing the impact wrench details, i'm confident that's what those dopes did -
oh well - least i can replace them pretty cheap -
I'll probably keep their 4-way iron just to be a d1ck. I don't really want them doing any more work on my truck-
i think the plug failed, i can see the original hole pretty clear (but would have to air and soap it up to confirm)
