First Truck!! 1500 Quad Cab
Old Jun 19, 2010 | 11:30 PM
Rx8freehk's Avatar
Rx8freehk
Default First Truck!! 1500 Quad Cab
Hello all, today we got our first truck! A used 07 1500 SXT Quad Cab with 44k miles on it.
Anything that I should be checking on?
It only came with one Key so Ive ordered a blank transponder key blank. As I understand it because I only have 1... I can only get it programed at a locksmith or dealership? Also is there an easy way to add Remote Entry to this? ( It has 4-door power locks)
I do have a question, The passenger tail light retaining clips have broken off (not on the tail light but on the vehicle side that holds them there). I did a search but couldn't find anything similar to what I'm looking for. Is there a simple fix?.. or somewhere that I can order them from?
Thanks! and so far were loving this thing!
-Matt
Old Jun 20, 2010 | 12:07 AM
Matt99's Avatar
Matt99
id check the local junkyards for the retaining clips...if you are talking about the black plastic circle part, someone on here said that you have to buy the entire taillight assembly to get that one little $0.10 part, I am missing one too....if you find one let me know!
The transponder key/programming is somewhat expensive, I got my dealer to give me an extra when I bought the truck. Most transponder keys have remote entry, my 07 does.....you might be able to buy lock actuators if you dont have power locks, if not you can buy a keyless entry kit and get it installed for a few hundred bucks
Old Jun 20, 2010 | 12:30 AM
hemiguy0302's Avatar
hemiguy0302
Congrats on the new wheels. Lets get some pic of this *****.
Old Jun 20, 2010 | 12:40 AM
nim81's Avatar
nim81
ya we NEED pics!!! welcome to DF!!
Old Jun 20, 2010 | 09:40 AM
HemiLonestar's Avatar
HemiLonestar
Ooh ooh, I got this one...
Wait for it....
Welcome to the forum!
Old Jun 20, 2010 | 10:10 AM
dirtydog's Avatar
dirtydog
Moderate User
^^..lol..I would have got that if you didnt Lonestar
Post up all your pics using a place like photobucket or similar.
Congrats on your new/used truck. I love the room of the quadcab!
Plastic clips...yeah, check salvage yards or ebay.
If it was me and I couldn't find a clip or had to buy the whole taillamp..I would just put a large blob of rtv sealant on the ball of the rod that goes into the clip and tape the light to your fender overnight. The blob of RTV must be large enough to grab the hole and make sure it won't drip to bad or fall right off.
I'd push the taillamp in super tight and then let it cettle back even this way the RTV sealant gets on the backside of the metal around the hole and holds the light there when dry.
I would have 2 keys programmed for a total of 3 because if you go through all this to get a 2nd key programmed and then loose one or it goes bad which it can....you'll have to do it all over again. Now, if you have 3 keys done and loose one, you can program the 3rd again yourself.
I bought the basic chipped key with no lock/unlock stuff on it because I wanted a less bulky key. I think the remote type keys are just to frickin big. Anyways, I paid $20 shipped for my key on Ebay and had the local Ace hardware cut it for $1 and I programmed it myself so the 3rd key will be super cheap. Good reason to do it now.
The only thing with that is...no warrant against them cutting it wrong but your saving $70 in the process so I'd take a chance on even cutting 2 keys wrong because you'll still be ahead.
Old Jun 20, 2010 | 01:27 PM
lxman1's Avatar
lxman1
Site Moderator
That's what I did, bought a non-remote chipped key, had Walmart cut it and for $21 have a 3rd key to either drive the truck or have 2 working keys in case I ever need to replace one, I can without having the dealer reprogram my wallet to empty.
Old Jun 20, 2010 | 06:09 PM
OklaHemi's Avatar
OklaHemi
Welcome to df. Congrats on the ram
