4.7 bored
Old Jun 22, 2010 | 07:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said before, boring out a cylinder will not change anything on the PCM. It will slightly lower the CR due to the cylinder being slightly larger but nothing noticeable IMO. But thats assuming you are using the same CC'ed pistons.
Old Jun 22, 2010 | 09:00 AM
HemiLonestar's Avatar
HemiLonestar
Will not make for a noticeable difference (especially at .020).
Old Jun 22, 2010 | 12:36 PM
2006NightRunner's Avatar
2006NightRunner
.020 bore will only give you about 3-4 more cubic inches on a 4.7L engine. This means only about 3-4 more horsepower, all things being the same. No PCM programming is not required for that small of change.
