05-prior guys with fogs on w/Highs please chime in
Old Jun 20, 2010 | 09:50 AM
dirtydog's Avatar
dirtydog
Moderate User
Default 05-prior guys with fogs on w/Highs please chime in
Simple yes or no will do.
I'm working on a Fogs on w/highs for the 06+ guys. My question is this:
Do your fogs come on everytime your highbeams are on even when the fog switch is turned off?
Basically, I can get the fogs to stay on with the highbeams no prob., but it requires the fogs to come on everytime the highs are on regardless if the fogs are not actually turned on. So, if the fogs are turned off and you flick your highbeams...The fogs will come on with the highbeams.
I'm sure I can work on something that isolates the 2 seperately, but it's gonna require dual relays and a lot of work and I wanted to keep it as simple as possible. Eitherway, it's not gonna be hook a wire like the 05-prior guys due to the canbus integrated module in the 06+ trucks since everything is sent through IC chips. It'll be a little more involved, not much though
Old Jun 20, 2010 | 10:51 AM
nozmadd0x's Avatar
nozmadd0x
I just did the one wire relay and now my fogs come one no matter if i just have the running lights on, the lows or the highs, whenver I flip the switch the fogs are always on.
Old Jun 20, 2010 | 11:00 AM
HammerZ71's Avatar
HammerZ71
I can't say for 100% certainty because when I wired my off-road light relay to my fog relay (so I didn't have to mount a separate switch for the off-road lights) I pulled the wire to the highs. The two wires made the relay not want to go down all the way in the socket and I didn't wanna force it. I have been planning on tapping the high relay into the new wire before the fog relay to remedy this, but it's one of those "back burner" things...
But to the best of my recollection, the fogs were NOT on unless the fog switch was on before...
Old Jun 20, 2010 | 12:05 PM
AF_HEMI's Avatar
AF_HEMI
I like how "a simple yes or no will do" got 2 paragraph replies lol
Old Jun 20, 2010 | 05:11 PM
HammerZ71's Avatar
HammerZ71
Well I had to explain why I couldn't just run outside and throw the switch and know... LOL...
Old Jun 20, 2010 | 05:53 PM
OklaHemi's Avatar
OklaHemi
Yes. For the 06+ you can have the puter flashed to have them stay on via dealership or a bullydog programmer. Turn the foglight option off and turn it back on and set to export. It's legal in Canada ay
Old Jun 20, 2010 | 06:20 PM
dirtydog's Avatar
dirtydog
Moderate User
I already know you can have them enabled with highbeams using the Starscan tool from the dealer, but I am trying to create the Fog Mod for ~$5. Did you even read my thread fully?
I can easily keep the fogs on when the highbeams are on BUT then the fogs come on whenever the highs are turned on even when the fog switch is turned off. It's not an issue, but it's not correct and really shouldn't be used with halogen bulb guys only HID guys due to the less amperage drawn through the wires.
Thanks for the response Hammer, I figured your response would be fully winded with all the wiring you got going on.
Old Jun 20, 2010 | 11:32 PM
gasguy's Avatar
gasguy
[quote=dirtydog;2173736]
I can easily keep the fogs on when the highbeams are on BUT then the fogs come on whenever the highs are turned on even when the fog switch is turned off.....
dog, will you share what you have or do you want to wait until it's figured out. I do a lot of back road driving @ night and could use the highbeam/fog combo. either way, i'm ready to see what you came up with.
Old Jun 20, 2010 | 11:52 PM
RedTruck-VA's Avatar
RedTruck-VA
Dog if you use a diode in the line connected to the highbeams it will prevent the fogs coming on unless the fog switch is turned on. I made mine a stand alone system and use them as DTRL controlled only by a rocker switch.
