3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Here you go, yes you will need to snake the bolts throught the brace. Usually use a wire around the threads and pull it through the mounting holes. Good luck.
Thank you VERY much for taking the time for this! Is that all your hitch is?? Looks nothing like mine! Hahaha
