HELP!! PCM/ECM/Check Engine P0601
Subscribe
Jun 22, 2010 | 09:25 AM
NEW TO THE SITE
2002 Dodge Ram 1500 4x4 5.9 Auto Quad Cab 120K Miles
So my check engine just came on and a mechanic ran the code. P0601. Internal Memory Whatever Error. I searched the posts and on here for help. I've disconnected the negative battery terminal and removed the ECM fuse (Fuse 19). Light went off, but came back on shortly after both both times. I'm afraid Im going to have to get a new PCM/ECM (Same Thing??) Ive found a used one on Ebay:
http://cgi.ebay.com/ebaymotors/02-DO...Q5fAccessories
Should this be compatible with my truck? Do i have to have it flashed or whatever? Not real familiary with the PCM for these trucks. Are there any other tricks I can try or am i going to have to buy a new PCM?
Any help would be appreciated. THANKS!!
Reply 0
Jun 22, 2010 | 11:39 AM
has your pcm ever been flashed? there is a tsb on flashing the pcm
if not im sorry but replace the pcm.
Reply 0
Subscribe
