Loud pop sound.
I was leaving work this morning and went to grab a bite to eat and when i tuned left into the parking lot, i heard a loud pop sound from the driver side front end. so i turned right an nothing... so when i was leaving i turned left again an, pop... got home and i looked under it and did not find anything out of the norm? what do ya'll think it could be?
MIne did that for a while too, never could figure out what the hell it was, had it up on a lift and checked everything and all was good still handled right etc. but it went away after a few months
Yeah its 4wd and it is used A LOT lol, i wiggled every thing i could think of, and nothing was lose. first time it has ever done it. maybe it will go away after some time... at least i hope.
The pop is probably from turning all the way and touching the steering stops. When the wheels get turned at that sharp of a turning angle, the pressure/weight of the truck can almost snap it into the steering stop causing a clunk/pop sound.
I don't think it's something your gonna get rid of, but you can reduce the noise by applying some grease to the stop face. The grease will act as a cushion.
It is a 2006 mega cab 1500...
and Thanks dirtydog i will most def try the grease.
and also, how do you add a Sig... to your posts? i must be blind because i can not figure it out :-/
