'02 1500 5.9L Plug Fouls Constant
Old Jun 25, 2010 | 10:05 PM
jimmygunns's Avatar
jimmygunns
Default '02 1500 5.9L Plug Fouls Constant
I've been going through plugs like cazy since about 45k. Now I'm at 94k. I've replaced the cap & rotor, wires, & O2 sensors. Tried factory Champs, & others, only to keep burning them up. Injectors cleaned as well. I'm somewhat mechanically inclined, but not a pro by any means. Everyone I've talked to that is a gear head has come up only with what I have tried in the past. Got to be someone on here with another idea. Dealership just has a bunch of parts changers that troubleshoot only to the bad parts, not why the parts go bad.
Old Jun 25, 2010 | 10:24 PM
badblackram06's Avatar
badblackram06
What is it that is fouling them out? Oil or Carbon from the gas? Is it all of the plugs or certain ones?
Old Jun 26, 2010 | 12:22 PM
br77's Avatar
br77
I have a 03 with the 5.9 gas and the same issue, I would like to hear the cause. I put plugs in it once a year usually #8 code misfire I think it might be that plenum thing but im too lazy to install it and too cheap to pay 700$ to let someone else do it....
Old Jun 26, 2010 | 12:47 PM
Big_Wheel's Avatar
Big_Wheel
depends what your plug looks like.... does this help at all?
Old Jun 26, 2010 | 01:51 PM
lastrights's Avatar
lastrights
ya its your plenum doing that, look down your throttle body for oil. if theres oil you have too replace your belly pan. do you use alot of oil ?? do you notice a performace loss,milage loss ?
Old Jun 26, 2010 | 02:02 PM
dhvaughan's Avatar
dhvaughan
your 02 2500 5.9 is actually a 2nd gen truck which has the common plenum gasket failure. come over to the 2nd gen forum for a million posts about plenum and the Hughes aluminum plate repair. it'll fix you right up.
Old Jun 26, 2010 | 05:40 PM
nim81's Avatar
nim81
plenum +3
Old Jun 27, 2010 | 08:30 AM
jimmygunns's Avatar
jimmygunns
Ok, Ill look into that. It has been different cylinders that I've had the misfire codes show over the years. Now here's my other question. What kind of damage other than the plugs burning up, could this have possibly caused over the years? Other than the plug codes, I'v ehad nothing else to complain about this truck. I'm the original owner, so if anything is jacked up, it's my fault! I'm going to try to look for a few threads, but if anyone knows of one, please post me a link! I'm on call this weekend & haven't had much time!
Old Jun 27, 2010 | 02:02 PM
lastrights's Avatar
lastrights
nah just fix your belly pan and you will be good to go and change our plugs after you do it and it would help to add a 180 t-stat
http://www.hughesengines.com/Index/p...p?partid=22220
Old Jun 27, 2010 | 04:30 PM
nh5's Avatar
nh5
from the plugs fouling you might have took a toll on the cat also but this is all caused by the blown plenum gasket. Wait till you see your truck after the gasket is fixed. It's gonna feel so much better to drive
