wire diagram for driver window switch
Old 06-28-2010, 04:32 PM
brettj2408's Avatar
brettj2408
brettj2408 is offline
while the door panel is off or the switch is out just take a paper clip and in the pins connect the yellow to the tan and try and use your passenger side window control to see if it works.
I wouldnt splice the 2 together unless it really comes down to having to do that
Old 06-28-2010, 07:44 PM
kx250frider617's Avatar
kx250frider617
kx250frider617 is offline
well, it worked PERFECTLY!
Don't worry, its all soldered up!
Old 06-28-2010, 07:46 PM
kx250frider617
wow, sorry. Having some technical difficulties uploading these pictures.
Old 06-29-2010, 08:26 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Thats ok, glad to see you got it all worked out
Old 08-22-2014, 02:37 PM
arron979's Avatar
arron979
arron979 is offline
New Member
Question
I now this thread is old but has anyone else done this bypass ? any pictures ?
Old 08-23-2014, 12:36 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Yep, an old thread. It's a mystery to me why no one wants to actually fix the problem.
Old 10-11-2014, 01:17 PM
lassie19950's Avatar
lassie19950
lassie19950 is offline
I have a 2004 Dakota club cab, the passenger window will only go down from the drivers side switch. It will also work if power is applied to the Yellow wire.Does this mean that the drivers side module is bad?
Old 10-11-2014, 05:24 PM
DDay77's Avatar
DDay77
DDay77 is offline
Hi All,
All 4 of my windows did not work. Here is what I found: The wiring harness has something to do with the problem. Today (10/11/14) I popped off the master switch, and seen the wiring harness from the small plug (forward) wrapped around the larger plug (rear) harness. I said to myself: "Self, why is this wrapped around this way?" I unplugged both, sprayed electronics cleaner in the plug outlets, and let them dry. I then added dielectric grease to the entire plug area and snapped all back together. Nothing. I unraveled the wiring harness, and held the small plug in while adding pressure towards the front, and adding pressure on the wires while pulling on the harness. All 4 windows operated! So, that is why the harness is wrapped around the other one. It is to add pressure (tension) on the wires. I am still working on the permanent fix, and will add more information as it becomes known. So, it may not be your master switch, or the contacts. I hope this helps others.
Old 07-02-2017, 02:42 PM
John Sager's Avatar
John Sager
John Sager is offline
Default Wiring diagrams for power windows
I have a 2002 Dodge Ram 1500 Quad Cab with manual windows/door locks/mirrors. I have 4 new doors from a 2004, but everything is power. Does anyone have a wire routing diagram, and possibly a wire color code to show what wire does what?
Old 07-23-2023, 07:58 PM
JakBurnell's Avatar
JakBurnell
JakBurnell is offline
I could sure use the schematic of the wire colors for the dodge Journey driver's side window control. I'm going to have to temporarily wire a switch in to raise/lower my brothers driver window and can't find the colors anywhere. He's on disability, in Hot Texas and can't afford the panel yet. AC is broke too..The switch is physically broken. If you could please email me that schematic or colors for FL UP, FL DOWN and the common color I'd sure appreciate it. My email is jakburnell at gmail.com
Thank you in advance.
Quick Reply: wire diagram for driver window switch
