3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Am I required to remove some of the bolts that attach the bed to the frame in order to slide my trailor hitch out?? That's the only way I see it possible, just looking for confirmation.
i take it your doing a roll pan or something?
if i remember right i think 2 cargo bolts attach to the bed.
so you will need to take them out and re install.
I have removed those two bolts (closest to the rear of the truck) but that hitch will not budge and I don't see any room for me to pull that thing out unless the bed comes up.
Yes, it's for a rollpan installation.
Dodge designed it so the bed would have to be lifted up. Pull the 4 bolts that go through the tow bar and frame. Then remove the 4 bed bolts closest to the rear, loosen the two by the cab. I had to lift my bed completely off the frame when i did my roll pan because the bed hit the cab before i had enough room to pull the tow bar out.
