Location of headlight relay please!!!!
Old Jun 30, 2010 | 12:34 PM
brettj2408's Avatar
brettj2408
one of them is more than likey an early build. some 02's have 2 connectors on the backside of the headlamp switch.
the 2 way connector is the 02's fog lamp control and ground if i remember correctly.
and next to the 2 way connector is a 14 way.
your 02.5 - 03 whatever it is has only an 8 way connector (from what i am reading)
Old Jun 30, 2010 | 01:03 PM
JJK's Avatar
JJK
Correct, but I had to check anyhow
Old Jun 30, 2010 | 01:26 PM
brettj2408's Avatar
brettj2408
so you couldnt have swapped headlamp switches to verify its your switch?
Old Jun 30, 2010 | 01:39 PM
JJK's Avatar
JJK
Switches are identical, put mine in the company truck and all lights worked. Put the one of the company truck in and no low beams. Identical plug ins on the back but yet mine worked when I installed it in the company truck
