Acc ignitiion tied wire
Looking for a ignition feed wire under the dash. A 20amp wire will suffice. Looking to wire in some LED's.
wire color and location would be great.
Thanks
2006 Quad Cab diesel.
Thanks
Since you are only using LEDs and they use very little power, why not use the cig lighter or even the accessory light wires in the center console?
But if you really want the ign wire, it is pink with a white stripe
Agreed! They will draw next to nothing...plus its easier to hide wires behind there...instead of tying them up under the dash
Under the steering wheel, behind the knee bolster is a four-wire harness. The lime green/black stripe is a switched hot. I use it to run through a switch to my driving lights relay and before the switch to my e-fan relay.
