Need advice
Old Jul 3, 2010 | 09:14 PM
midd4060's Avatar
midd4060
Default Need advice
I have a 2008 quad cab 4x4. I'm getting a 2 inch leveling kit installed next week. Hopefully soon after, I'm going to purchase new wheels and tires. What is the biggest tire I can go to? Also, I have 20's now, but I am considering going down to 18's to save some money. Anyone have any other advice?
Old Jul 3, 2010 | 09:17 PM
BadHab1t's Avatar
BadHab1t
https://dodgeforum.com/forum/search.php
this lil link here helps with these questions as they are asked everyday so there are hundreds of threads that have the answer a hundred times....35's no more...
Old Jul 3, 2010 | 09:39 PM
Big_Wheel's Avatar
Big_Wheel
also... 17"s are even cheaper :P btw welcome to the forum!
Old Jul 3, 2010 | 09:42 PM
BadHab1t's Avatar
BadHab1t
yes 17 and 20's are the cheaper of the bigger sizes as my buddy works at a wheel shop and he said 18 are more expensive than 20" wheels...were talkin rubber not rim....
Old Jul 4, 2010 | 04:01 AM
brettj2408's Avatar
brettj2408
make sure if you go smaller rim it will still fit around the rotor/caliper. I beleive 17 is the smallest your able to go.
Old Jul 4, 2010 | 07:24 AM
HammerZ71's Avatar
HammerZ71
17's would save you a lot of money over 20's, not to mention on a 4x4 would perform better off-road AND give you a HIGHER towing capacity...
Old Jul 4, 2010 | 07:47 AM
dirtydog's Avatar
dirtydog
Moderate User
'bout 1,000lbs more on the towing...IF going with stock 17" sized tires I believe. 20's are reduced towing because of the total diameter being larger than stock 17 rubber...33" vs 31" I thought???
If your gonna go with a 35x12.5xwhatever, and your getting aftermarket wheels, your gonna want to get a backspacing between 4.5-5" depending on the rim width.
