Towing RPM????
I have a 2002 Ram 2500 5 speed Magnum and just bought a 30ft 5th wheel trailer, my question is how high should I go in each gear for RPMs before changing gears? Any help would be great. I heard that you should go higher on the RPMs than normal when towing a big trailer
Yeah, a ltittle higher is good so that it puts you more in the powerband because as you shift, your slowing down and so is the motor when it goes into the next gear. Your basically setting the engine speed up for the next gear. So when you get into the next lower gear, your engine speed is high enough for you not to lug.
Your rpm just depends on the weight being towed and the incline/decline travled on.
I would say that you would want to run upwards of 3500-4k for taking off and you'll wanna cruise right around 2-2500rpms or so. That's just a generall assumption. Drive your truck so the trailer feels "lighter" yet don't scream the crap outta your engine as there's no need.
You'll get the feel of how high you must raise the rpms before shifting into the next gear. It may take a few stops before you figure out the sweet spot, but you should be fine. i think it'll tow better than you think.
Thanks again for all your help, I will let you know how I made out. CHEERS JODY
