Need Wheel Hub Assembly + Rotors
My right bearing took a crap. Not a big deal since I need to replace the brakes/rotors and shock so might as well do it all at once. Have you any input on what is a good brand to go with - if there even is more than one? The local store said they have national wheel hub assembly in stock and the only other type I found was timken...any input?
While I got you here, I was looking online for some decent (not crazy) rotors. I found Power Slot Cryo rotors (they are not drilled out) along with power slot pads w/ 36,000 mile warranty. Just curious if anyone has used or at least heard of these?
Thanks for all the help.
Yeah timken is how I was leaning. Besides if the local auto store doesnt carry a brand and I find it online, its generally better overall. Sad to say, sadder to say that my 03 only has 72000 miles and I am replacing the wheel hub assembly. Thanks for the info.
Trending Topics
true but cant you take the old one off your original hub and put it on the new one?
I don't know if you can take the old one out Weed???
Indeed, my son tried to take out a sensor in a Toyota last year and due to the heat and corrosion etc, the thing just ended up in bits.
Al.
Al.
