takin off the powerwire lol
Old Jul 13, 2010 | 12:52 AM
  #21
Nate769's Avatar
Nate769
Originally Posted by Plainbroke
Jus, Why don't you make him another and let him try it to see if you got a bad resistor, anything is possible. Worth the 50 cents to keep a good rep on the site isn't it?
agreed....i installed one as well with absolutely no issues....it is possible that you do have a bad resistor...things can happen, i have seen that. Its rare but its possible. Depends on the maker and the quality too...
Old Jul 13, 2010 | 06:25 AM
  #22
weedahoe's Avatar
weedahoe
Hall of Fame Member
Those 1/4w 4.7k ohm resistors are small and cannot take much heat. I take my resistor leads and bend them in half, dip them in flux and tin them very quickly. I take my wires and tin them also and then simply touch the wire and resistor together and blow them off to cool faster and that is all done in a split second. If you heat the resistor too much you will damage it.
After letting it cool, always check it with a meter to see what the resistance measurement it to make sure it is not damaged
Old Jul 13, 2010 | 08:58 AM
  #23
nateroach's Avatar
nateroach
OP, just throw a multi meter on the power wire and see what you get. if it isn't 4.7k ohms +-~5% you know its a bad power wire and you could get/make a new one. If it meters out correctly, remove it and see if it fixes your problem. Simple solution.
nateroach
Old Jul 13, 2010 | 10:39 AM
  #24
dirtydog's Avatar
dirtydog
Moderate User
Weed...That would make a great DIY video. If your up for it?
Old Jul 13, 2010 | 10:46 AM
  #25
weedahoe's Avatar
weedahoe
Hall of Fame Member
I might have to work on that for you. I will see what I can do.
Old Jul 13, 2010 | 09:50 PM
  #26
moparmike01's Avatar
moparmike01
why dont you buy the power air one
Old Jul 15, 2010 | 03:39 AM
  #27
Michael0077's Avatar
Michael0077
i'm not quite sure what that is ... do you mean the one from ramair?
Old Jul 15, 2010 | 07:50 AM
  #28
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, thats the one. The only issue with that is it cost $55 new and it is the exact same 4.7k ohm 1/4 watt resistor in it too but just a bit more fancy with nice OEM plugs on it.
