Someone please help!!!
Old Jul 10, 2010 | 10:40 AM
AF_HEMI's Avatar
AF_HEMI
move it somewhere else. disconnecting the nut at the top of the UCA allows the whole spindle to rotate down. disconnecting the nut at the tie rod allows the spindle to swivle. if you have your jack under the LCA, the spindle cant move. relocate it to under the frame just behind the wheel
Old Jul 10, 2010 | 10:41 AM
Kejacobson's Avatar
Kejacobson
I think I'm gonna move it, lol.
Old Jul 10, 2010 | 10:43 AM
abarmby's Avatar
abarmby
Yep move it to make you safe and so you have access.
AL.
Old Jul 10, 2010 | 11:32 AM
Kejacobson's Avatar
Kejacobson
Well I've been pounding on the spindel since my last post and have yet to break the seal between the upper control arm or the tie rod end. Might see if a friend has one of the wedge forks...or get a bigger hammer
Old Jul 10, 2010 | 12:15 PM
Kejacobson's Avatar
Kejacobson
Allright guys...a much appreciated thank you for all you help. I got the upper control arm off and tie rod. Slipped the axel far enough back to get to the bolts and presto hub assembly off. And barely had to work it off which was a blessing
Old Jul 10, 2010 | 12:28 PM
abarmby's Avatar
abarmby
Great news bud.
I knew it would work out for you.
Just make SURE, that you re-torque all the bolts to the correct values ESPECIALLY the large hub nut.
Improper torqing of that, can lead to CV axle failure apparantly.
Al.
Old Jul 10, 2010 | 12:31 PM
Kejacobson's Avatar
Kejacobson
I'm glad you brought that up. i was gonna ask if anyone had the torque spec's for all the bolts. I've heard that the axel nut is 180pds. But have no idea on the others.
thanks
Old Jul 10, 2010 | 12:50 PM
abarmby's Avatar
abarmby
Here you go straight from the 2004 Dodge Manual for a 1500 4x4:
1) Install the hub/bearing into the steering
knuckle and tighten the bolts to 163 N·m (120 ft.
lbs.)
2) Install the upper ball joint nut to the steering
knuckle and tighten to 54 N·m (40 ft. lbs.) (on 1500
series only an additional 90° turn).
3) Install the tie rod end nut to the steering
knuckle and tighten to 61 N·m (45 ft. lbs.) then an
additional 90°.
4) Install the halfshaft nut and tighten to 251
N·m (185 ft. lbs.).
So your WAY out on your halfshaft nut.
It MUST be torqued to that value for reasons mentioned above and by advice from some CV half shaft manufacturers.
See here:
http://cardone.com/english/club/Prod...%2060-0002.pdf
And
http://cardone.com/english/club/Prod...%2060-0004.pdf
Plus:
http://cardone.com/english/club/Prod...%2060-0001.pdf
Hope all this helps?
Al.
Old Jul 10, 2010 | 01:02 PM
Kejacobson's Avatar
Kejacobson
Perfect...that's what I was looking for. Again, much appreciation
Kevin
Old Jul 10, 2010 | 01:11 PM
abarmby's Avatar
abarmby
No probs Kev.
Good luck on the repairs bud.
Al.
