Rear end Squeking, slight vibration?
Old Jul 12, 2010 | 05:56 PM
06 RMK 900's Avatar
06 RMK 900
Default Rear end Squeking, slight vibration?
Ok I have searched the forum a bit and came up with nothing.
If I go slow forward or reverse I can here a squeking noise coming from under the bed. I have lifted the truck up on the hoist and checked everything and I can't find what it is. I moved the tires while on the hoist and it's nothing when I turn the tires.
I was told maybe a U-Joint is going out??? After about a 20 minute drive I took my laser heat thing and the front U-joint on the rear axle is about 5* warmer then the rear. You guys think thats what my problem is? Only other problem I can see is if i'm going about 65+ and I let of the gas I can feel a slight vibration until I hit the gas again then it goes away.
Old Jul 12, 2010 | 06:05 PM
Marx's Avatar
Marx
check out your leaf springs it could be rubbing the shackle, or a bad bushing
Old Jul 12, 2010 | 06:15 PM
pousaan's Avatar
pousaan
I can 99.9% say your rear u-joint is rusty and isn't moving freely, it's sort-of binding up.
I had the exact same issue and symptoms and just had my rear U-Joint changed out. It was covered under my powertrain warranty.
Old Jul 12, 2010 | 07:30 PM
brettj2408's Avatar
brettj2408
my bet is u joint as well.
i would replace them both
Old Jul 14, 2010 | 12:35 AM
06 RMK 900's Avatar
06 RMK 900
Well went and picked up new U-Joints today. Dealer wanted $90 a peice got them at O Rileys for $12 a peice. Going to put them in tomorrow night I hope.
Old Jul 14, 2010 | 07:10 AM
NewfieMegaCab06's Avatar
NewfieMegaCab06
Remember...!!!! if you don't see the C-clips on the U-joint caps you have the plastic injected ones. So if you heat them up before you press them out it will make your job got alot faster and easier... I just replaced all three of mine on my Mega Cab... It had the same exact problem... If you feel the viberation in your butt Than its 99.9% chance your U-Joints....
Good Luck...
Old Jul 15, 2010 | 12:02 AM
06 RMK 900's Avatar
06 RMK 900
Well it was a very easy project was done in about 45 minutes. I have changed tons of U-joints on farm equipment but never on a vehicle. I got lucky and had snap rings and didn't have to get the torch out.
The U-joint was defiantly the problem the back u joint there was one that had no grease on it at all. No more squeaking.
Thanks for the input everyone.
