egr
Old Jul 13, 2010 | 11:07 AM
hemihead104's Avatar
hemihead104
Default egr
i have a 2004 1500 5.7 and check engine light has been coming on more and more frequent. i have a superchip programmer and the code is reading erg circulation high. anyone else having this problem
Old Jul 13, 2010 | 11:09 AM
brettj2408's Avatar
brettj2408
egr valves are pretty common on the hemi. i have seen them last longer than 100k but also less than 30k.
Old Jul 13, 2010 | 11:11 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Go buy one at Autozone or someplace like it for $40 and replace it
Old Jul 13, 2010 | 12:02 PM
sbsga's Avatar
sbsga
when you replace the valve you should also replace the sensor, and your egr is part of your vac system so make sure you have it sealed correctly or you will have some idle issues
Old Jul 13, 2010 | 12:09 PM
brettj2408's Avatar
brettj2408
yes good point, as well as the gasket
Old Jul 13, 2010 | 12:50 PM
HammerZ71's Avatar
HammerZ71
EGR valve is a disposable or "normal wear" emissions part. As was said, go get you a $40 one at an auto parts store or goto the dealer and get one for $70 and swap it out.
Then you're good to go for about another 40-50k miles till the light flashes for it again...
Old Jul 13, 2010 | 02:54 PM
ffrescue724's Avatar
ffrescue724
I had the same issue with mine. Ordered my EGR from Rockauto and had it in 2 days. Swapped it out in 10 mins, reset the PCM and away went the light. Easy fix and like the guys said you can do it for under $40 bucks.
