Oil pressure woes, rebuilt engine
Old Jul 26, 2010 | 08:36 PM
Biggrhammr's Avatar
Biggrhammr
Ok, just curious, does anyone know, if the bolt is removed from the primary chain idler sprocket, would oil flow out of that hole? According to the lubrication chart, it looks like it would.
Old Jul 26, 2010 | 09:27 PM
Biggrhammr's Avatar
Biggrhammr
Ok, does anyone know, if the bolt is removed from the primary chain sprocket, would oil flow from that hole? According to the lubrication chart, it looks like it would.
Old Jul 27, 2010 | 07:45 AM
Gasturbine's Avatar
Gasturbine
Originally Posted by Biggrhammr
And as far as the oil filter goes, wouldn't a clogged oil filter cause high pressure, instead of low pressure?
No. Oli pressure sensors are always set at the highest point possible, after the filter.
Old Jul 27, 2010 | 10:19 AM
Biggrhammr's Avatar
Biggrhammr
Anyone?
Old Jul 29, 2010 | 01:09 PM
Biggrhammr's Avatar
Biggrhammr
Well, as much as I'd just like to let this thread die, and not admit stupidity, I won't. I put this engine together, and didn't reinstall the primary chain idler sprocket bolt. If I had followed the manual, I would have noticed it missing when checking end play, but my attention was deverted to getting the timing correct. Even worse than that, I saw the bolt sitting there when I was all done, it was the only thing left, and I searched and searched my memory, and couldn't remember ever taking it out of the engine, and determined that I had set it there from another project (which I'm pretty religous about not doing). So that's it, oil problem is now solved, and the truck runs great. I'm praying I have no lasting effects from this other than my pride.
Old Jul 29, 2010 | 01:27 PM
RedTruck-VA's Avatar
RedTruck-VA
I knew you'd figure it out, like I said you were the one working on it... well done..
