nitrious ?
Old Jul 14, 2010 | 12:14 AM
moparmike01's Avatar
moparmike01
Default nitrious ?
Hey guys what you recommend the truck can handle as far as a ntrious shot? You think that a 100 shot is alot?
Old Jul 14, 2010 | 12:56 AM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by moparmike01
hey guys what you recommend to spray nitrous with like a 100 shot would be too much intake exhaust headers diablo ported tb you think it can handle it
huh???
Old Jul 14, 2010 | 01:10 AM
moparmike01
Sorry i changed it just realized what i wrote.
Old Jul 14, 2010 | 01:31 AM
dirtydog's Avatar
dirtydog
Moderate User
I personally wouldn't use a dry 100 shot. I'm a wet kit guy mainly because it's much more accurate and doesn't work the injectors anymore than stock.
With that said, I think 100shot is perfectly fine on a stock block granted you have safety measures such as fuel saftey shut off valve...etc,.
I wouldnt go anymore than a 100shot without internal work or a custom tune.
You'll ned to run premium octane..93,, and you;ll need to drop to a colder plug and reduce the gap. There is a side effect in doing this. You WILL lose some performance when NOT using the nitrous by doing so. It's a trade-off that may not be worth it to you likely won't be using nitrous the majority of your trsvels. It's like a sunday treat or the most part as it's very expensive and tough on your motor.
Old Jul 14, 2010 | 08:29 AM
nateroach's Avatar
nateroach
Quite a few guys on DT running NOS you might check there too. 100 shot seems to be pretty common on stock lower ends. those with forged lower ends are running 150 shots.
nateroach
Old Jul 14, 2010 | 10:42 AM
moparmike01
ua o be running wet i got all the stuff i need to use thanks guy i ask on dt too i thought 100 shot be fine also
