Car Alarm Chirps w/Driver's Door Open
Old Jul 16, 2010 | 01:25 PM
cfd303's Avatar
cfd303
Default Car Alarm Chirps w/Driver's Door Open
Noticed yesterday the drivers door was open and when I inserted the key into the ignition and turned the key to on (not start) the horn chirped and the hazard lights flashed. it would do this as long as the drivers door was open.
1. Is this normal?
2. How do I unprogram this feature?
It has also happened when I left the truck in gear with the park brake set the car alarm will activate. Is this normal?
2006 Ram2500 Quad Cab 5.9L diesel
Old Jul 16, 2010 | 02:50 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
It did it once but can you replicate the issue over and over? Do yuo have a over head display (OHD) with EVIC (garage opener, ect)
Old Jul 16, 2010 | 08:22 PM
SilentRamAD's Avatar
SilentRamAD
My truck does a constant half second or there about chime over and over as long as the key is in the on position and the drivers door is open. As well as if I leave my lights on and take the key out, it'll continuously chime.
Hope this helps. As far as disabling the feature
