Wiper Motor Electrical Connection
Old Jul 22, 2010 | 07:42 PM
oiscoot's Avatar
oiscoot
Angry Wiper Motor Electrical Connection
I went out to truck last night and turned the wipers on to go to get me a pastrami on rye! Wipers didn't work!!! Took connection off motor and tested voltage...had 12 volts with switch on, so assumed motor was bad. Tried to open up the motor after removing the entire arm assembly. contacts look fine! used eraser to clean and relube still no luck. Orderd new re-man motor from parts store local. went to pick it up tonight...the wiring connection is a 4 pin oval connector!!! Mine is a 5 pin trapazoid connection in truck!!! WTF!!! Called the dealer and they had motor in stock...had him pull it to see connection...same 4 pin ...WTF!!! But he said they sell a wiring kit...but dont have it in stock and is special order...WTF...ready to snap on DODGE!!! Has anybody had this problem and what did you do to resolve it? Is there a wiring diagram I can use to repair this new motor?
