3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
So, I have looked everywhere and keep coming up with it's as simple as pulling one wire from the harness in the 03 Rams but am reading that Dodge has kibosched that option in the 3rd gen and up models. Without a programmer is it possible to disengage the Torque Management or am I **** out of luck? Also is there a torque management system in the tranny as well? Thanks guys.
IDK about pulling a wire from the harness, but SuperChips has TQ management out right now. Go look in the SC forum. You can't completely disable TM, but you can reduce it.
Yep, tuner is the only way... and well worth the investment, IMO...
Superchips being the ONLY one right now. Flashpaq 3865 or Cortex 3950. You'll need to purchase the trans support feature on top of the tuner. I believe it's $40? right now. Well worth the trans functions as you'll have MUCH more than just TM control.
