Leveling kit
Old Jul 27, 2010 | 08:19 PM
Calvert's Avatar
Calvert
Default Leveling kit
Ok so im thinking about putting a 2.5 inch leveling kit on my front end of my 2wd 03 ram so i can fit some 33's or 35's...
1) Is this relatively easy to install?
2) Can i instal a lift at a later time?
3)Is 80 bucks a good deal?
Old Jul 27, 2010 | 09:06 PM
cam01ss's Avatar
cam01ss
what leveling kit does everyone recommend? i want something that you dont have to disassemble the strut if possible. also would like a good quality so what does everyone have to say about it. also how high 2" or 2.5"
Old Jul 29, 2010 | 02:48 PM
Calvert's Avatar
Calvert
im thinking 2.5 just to make sure i can clear some bigger tires...probably do a 2.5 level and then a 3 inch body lift so i can get some 35's under there.
Old Jul 29, 2010 | 02:55 PM
Gasturbine's Avatar
Gasturbine
I got 2" out of the front of mine, by adjusting the torsion bars. It took 5 minutes, was free, looks level, and Im running 32s with room to spare. Ive even heard of guys going 3" with longer adjustment bolts.
But mine is an '05...I dont know if an '03 has the same set up.
Good luck.
-Chris
Old Jul 29, 2010 | 04:31 PM
bobb050's Avatar
bobb050
Did that stiffen your front end up much? It seems like it would.
Bob
Old Jul 29, 2010 | 04:53 PM
CardinalsFan11's Avatar
CardinalsFan11
If you have a 2WD then the biggest leveling kit you can put on is 2". Or at least that was my experience with the 2wd.
Old Jul 30, 2010 | 08:26 AM
Gasturbine's Avatar
Gasturbine
Bob
Nope. All your doing is changing the position of the stop...the rotational integrity stays the same. If anything, it may soften you up a bit, by slightly changing your front/back weight ratio.
What it does do however, is slightly change your suspension geometry, and add a little more angle to your CV joints. The latter has little issue, and I would recommend a front end alignment for the prior.
-Chris
