Engine Light Codes
Old Jul 28, 2010 | 09:28 AM
dodgegurl12's Avatar
dodgegurl12
Lightbulb Engine Light Codes
The engine light is on in my '05 Hemi. I have heard that there is a sequence you can do with your windshield wipers, the code will pop up, and then you can look it up on the internet and find out what the problem is with the truck. Does anyone know anything about this?
I have had this light investigated by Dodge twice already - at $175 each time!!!! NOT doing that again. Im almost better off buying my own reader!
Old Jul 28, 2010 | 09:45 AM
brettj2408's Avatar
brettj2408
key off, key on, key off, key on, key off, key on. (never start the engine)
the code will display on your cluster.
then list your codes...
Old Jul 28, 2010 | 10:00 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Or go to a auto parts store and let them connect a OBD scanner to your truck and get you the codes
Old Jul 30, 2010 | 08:22 AM
dodgegurl12
...P0430 - so more oxygen sensors! Im replacing the 2 on the left side now, did the 2 on the right a month ago! ugh. This Hemi.... Do you think if this code comes up again it will be the Cat? Im hoping so - thats still under warranty!
Old Jul 30, 2010 | 09:25 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Or a air leak. Check the header bolts and make sure none are broken as most people find broken ones
