Need to Level my Truck, already used a Leveling kit..
Old Jul 28, 2010 | 10:20 PM
CardinalsFan11's Avatar
CardinalsFan11
Default Need to Level my Truck, already used a Leveling kit..
So I've got a 2008 Ram Quad Cab 1500 2WD. The truck comes with a terrible rake of about 4 inches. As of now, I have a 2" Leveling Kit, and a 3" PA Body Lift. What other options do I have to lift it and make it level? I know there are the 4" CST spindles which I could use on the front, and put a 2" rear block in the rear? Is that the only other way of lifting a 2WD? Thanks in advance.
Old Jul 28, 2010 | 10:32 PM
HammerZ71's Avatar
HammerZ71
You sure you don't have any issues with that front end? I helped my cousin with an '08 4x2 Hemi put in a set of 2" coil spacers last summer and it measures less than a half inch of being perfectly level...
Old Jul 28, 2010 | 10:33 PM
luckydt's Avatar
luckydt
not positive, but i would assume the 2wd is much like the 4wd in that when i did my suspension lift i bought new leafs for the back and i got to choose from a couple different sizes i went with 5" lift in the back 6" in the front.
Old Jul 28, 2010 | 10:37 PM
TRXHemi's Avatar
TRXHemi
I have a 2008 2wd and I did a 2" leveling lift also......after all settled down, I am about a half inch off....
Old Jul 28, 2010 | 11:24 PM
oefootball_70's Avatar
oefootball_70
lowering shackles in the rear.....
Old Jul 28, 2010 | 11:46 PM
Freakinkeith806's Avatar
Freakinkeith806
my 07' is pretty dang close to perfect..I wonder what would make it do this
