help with homemade cai
drill a hole in the side of the PVC just big enough so its a tight fit, then use RTV to seal it in place. Otherwise Bighorn777 found a gromet at the auto store that fits snuggly around the sensor....I just did the RTV and its holding up just fine
here you go man, here is the thread I started awhile back. It lists all the essentials needed to make a decent CIA that is in direct outside air flow and away from the hot stale engine air.. It even lists a grommet that you can use to seal the IAT sensor.. Hope this helps, post some pics when your done with it.
https://dodgeforum.com/forum/3rd-gen...fab-cai-2.html
